5th gen ES startup rattle mythbusters edition
Both my cars with 2GR engines have this noise on extreme warm days, and the cause is the oil drain from the OCV. I believe that the post #36 in this thread explains it very well:
http://www.toyotanation.com/forum/8-...tart-up-3.html
I am not going to fix anything on either car...
up to you whether to fix it or not
but i was told by a Lexus Master Tech who travels the dealerships throughout US that this will ruin the entire vvt system (the gears will crumble)
Each service case is unique with different root cause and until it is repaired for good, one won't know what the true cause was, and stating:
Originally Posted by heidihidin
if your issue is similar to this, get rid of the car while you still can
It’s not under the intake manifold. You can set up blue circle, it’s on the left of the intake manifold.
nelsona
ES - 6th Gen (2013-2018)
01-24-20 03:17 PM
funcrusher
07-10-18 03:31 PM
wanderer99
ES - 5th Gen (2007-2012)
30
01-17-07 05:55 PM
