how to install Iphone 6S into 2007 Lexus 350
I have one. Not sure what you are asking. There is no install per se that I am aware of. Just charge it thru one of the cigarette lighters. There are numerous cheap devices that you can use to keep the phone attached to the vents.
If you're asking how to connect the phone to the audio system through a Bluetooth connection the procedure is detailed in the quick reference guide and the owners manual.
if I remember correctly, while the car is not moving, push the "Info" button, select "Phone", then select "Choose Phone" (this may say "Connect". Can't remember.). If there is not an "empty " spot, you'll need to delete one. I can't remember exactly how to do this. It may be under "Settings ". The connection requires that you type in an access code that's displayed. You can change the code in settings, I think.
Ericspyder
11-16-17 10:27 AM
qnhuly
ES - 5th Gen (2007-2012)
08-24-10 09:07 AM
