Rear speaker deck rattle?
As the temperature has increased, the rear speaker deck lid is suddenly making an irritating rattling noise when strong (or medium) bass is played. Has anyone else had this happen in warm weather, or is a screw possibly loose? Thanks.
2008 ES
2008 ES
i have not had this issue but the 5th gen Es a just prone to rattles in extreme temps dealer told me when temp is above 80 or below 20 doors, sunroof, windows will rattle on this car (only when under load) Due to the way the engine is mounted
camry with same engine does not have this issue
May want to check and see it's not coming from above the rear part of the headliner. I had a similar rattle that I thought was either the rear suspension or maybe the rear deck but it ended up coming from above the headliner where it meets the rear windshield. I could replicate the noise but lightly hitting the top center of the rear windshield from inside the car.
