Crank but No start
Crank but No start
Yesterday morning on a cold start.. My es 2007 cranking without start.. Check the batteriw, spark, fuel are fine.. Towed to mechanic today.. Any idea what would be the cause of problem while waiting for mechanic diagnosed.. He said can't use obd scan tool since the car is dead.
thanks
J
thanks
J
Something's not adding up.
If it will crank and your battery is good how is it too dead to use the scanner? Maybe a blown fuse killing the port?
If the battery, spark, and fuel is good, you're not getting enough air or you have a compression issue.
Do you have a CEL?
Do you have a CEL?
The mechanic just called.. The car started just fine.. He think it head gasket leak, some coolant got into engine, it start only when coolant dried up. He recommend stop leak for temporary solution, or if I want to open up the engine for gasket replacement, that would be costly on labor.. PS. I just got new radiator replaced last week
Then he doesn't THINK it's a head gasket he KNOWS it's a head gasket. Stop leak ain't gonna fix that. Time to reach into your pocket and pay for the fix. Hopefully there is no coolant in your oil . Better check that out because if there is then sorry but you'll need to replace the engine.
soggyjay
06-17-17 10:50 AM
