Need help with code P0368
Hi, i have a 2008 Lexus Es350 and I would like some help with this code P0368 any picture or video I would like to fix this myself having trouble locating this sensor
Any help would be appreciated.
2GR-FE ENGINE CONTROL SYSTEM: SFI SYSTEM: P0365,P0367,P0368,P0390,P0392,P0393: Camshaft Position Sensor "B" Circuit (Bank 1)
DESCRIPTION
The exhaust camshaft's Variable Valve Timing (VVT) sensor consists of a magnet and MRE (Magnet Resistance Element).
The exhaust camshaft has a sensor plate with 3 teeth on its outer circumference.
When the exhaust camshaft rotates, changes occur in the air gaps between the 3 teeth and MRE, which affects the magnet. As a result, the resistance of the MRE material fluctuates. The VVT sensor converts the exhaust camshaft rotation data to pulse signals, uses the pulse signals to determine the camshaft angle, and sends it to the ECM.
The troubleshooting is fairly long and technically detailed. Depending on the outcome of the testing you may need to replace the sensor, the connector, wiring or worst the ECM. I'm sure in most cases it ends up being the sensor.
DESCRIPTION
Where is Camshaft Position Sensor "B" Circuit High (Bank 1) located is different then a vvt sensor
Camshaft and VVT sensor is the same on this one.
Located in Bank 1 cylinder (firewall side under the intake plenum)
Sensor you are looking for is bolted on top of the valve cover with a 3 wire connector.
Exhaust camshaft side.
It will be hard to see since its under the plenum.
Here is a pic.
Hope this helps.
Here is a pic.
Hope this helps.
[QUOTE=Nad1370;10471586]
Here is a pic.
Hope this helps.
Is it a pre cat or post cat camshaft position sensor for B bank 1 high input?
Here is a pic.
Hope this helps.
Here is a pic.
Hope this helps.
Here is a pic.
Hope this helps.
Camshaft position sensors are not installed after a catalytic converter.
papasito
01-01-17 08:21 PM
JRabs
11-01-09 07:39 AM
