08 ES350 one low beam and marker out - got wiring diagram?
08 ES350, non-HID
Passenger-side low beam and marker are both out.
All other bulbs work fine - everything on driver side. High beam, DRL, turn signal, fog on psgr side.
Low beam bulb is good. Swapped low beam fuses - no change.
Any thoughts on what might be going on here?
Is there a relay that only control the low beam and marker on one side?
Anybody got a wiring diagram for the exterior lights?
TIA
TIA
I will check the negatives on the chassis, they are behind the ABS module.
