ES350 2010 without Park Assist
Hello,
I just got an ES350 2010 which is currently on its way for delivery to me. I just found out it does not come with Navi and Park Assist.
Can I Park assist be installed to work with my ES350 and also what kit do I have to get..
Is there a tutorial guide on how to install the OEM park assist.
Hello,
Park Assist systems are actually pretty cheap and available on line. The sensors that would have
been color keyed to the car will be black (OK if your ES is Black, right?).
The 2010 ES Navigation is not worth retrofitting, you would not want your Motorola Razr back would you?
Lots of threads on mounting up your phone or an iPad mini to run Waze or other Nav apps.
Good luck and hopefully the wiring harness and the park module will be a plug and play. Without the nav. screen I don't know how it would work . Oh don't forget the on/off button on the lower left hand panel. Let us know how you make out as others might be interested in doing the same.
jeffmaggie
RX - 3rd Gen (2010-2015)
85
06-17-12 03:36 AM
