Can someone please confirm if the 2010 ES and LS share the exact same side mirrors?
Look carefully at the base connector, it is different.
https://www.ebay.com/itm/2010-2011-2...4AAOSwZbVcECuN
https://www.ebay.com/itm/2010-2012-L...gAAOSw5wFcQyuk
https://www.ebay.com/itm/Power-Mirro...wAAOSwCRxc0Tj0
Could you make them fit? Sure, cut some tabs or drill some holes.
If you call Rancho Lexus Recycling http://www.rancholexusrecycling.com/
they (and every other car recycler - junkyard ) has access to the Hollander Database which tells them what parts are interchangeable among different vehicles. That will provide a definitive answer to this endless thread.
If you want to install the LS mirrors on the ES then you have to drill new holes and you have to replace the harness connector and then the gap between the mirrors and the door will be much bigger than it’s now.
