VSC Warning light and TRAC slip indicator
I have a 2007 ES 350 with ~145,000 miles, which I bought new. I've had a recent issue with several warning lights coming on at the same time: the Malfunction Indicator Lamp, the Check VSC Warning light, and the TRAC Slip Indicator symbol showing all at the same time. No flashing or buzzer. When scanned it shows a P606 code. I've turned the code off a few times, trying to see when/if it would reappear. It has appeared twice when braking, and another time for no apparent reason. It seems to drive and handle fine (albeit on dry roads.)
I'm new to the forum, so bear with me.
