High cold start RPM
High cold start RPM
I have been searching and searching the forum but I have mostly found "its normal" but I feel like its not- cold start RPM 1800-2000 goes down to 900-1000 after 30sec- 1 min, goes down to 800ish when in drive- at least it goes down but no one else mentions up to 2000 RPM here.
2007 ES350
118k miles
Sometimes there is a fan squeaking noise but the car is just loud IMO, I wish the car was, in general, a bit quieter- what are my options?
When my dad comes into town this Christmas we will change the spark plugs and oil, not sure if this will help with the high RPM's or engine noise. I have seen everything from coolant temperature sensor to idle air control valve to fuel additives and I am just confused
2007 ES350
118k miles
That initial RPM level and kick down RPM is perfectly normal. As it gets colder, the initial RPM will get higher and the kick down will change to compensate for the temperature, thicker oil and ignition characteristics.
You could run a bottle of Techron Fuel System cleaner in the gas to clean out the throttle body and intake system.
I trust you know how involved it is to change the spark plugs. Have fun bonding with your father on this project!
Since you probably have to remove the intake manifold to change the rear bank spark plugs, that would be a good time to directly clean out the throttle body with some throttle body spray cleaner.
The fan squeaking noise probably means you should change your drive belt. Your father probably can help identify the noise.
use a strong concentration of fuel system cleaner
service your pan filter and trans fluid
do a brake flush
how often do you change your oil? if you go more than 5k per interval, do another oil change
have the suspension inspected
do you smell fuel when you start the car?
do a brake flush
do a brake flush
do a brake flush
Oil was less than 5k ago but it was also 6 months ago (before I purchased) so I intend to get that done.
How strong is the Lucas Oil fuel injector cleaner?
Now that you mention the smell I will inspect it today when I leave the office BUT I noticed white smoke last night long after the car was warmed up and the coolant was low, how hard is it to diagnose a coolant leak and what cost am I looking at? The engine does not overheat, the a/c blows hot and when I had last inspected the oil it was not milky.
Also, take your engine dipstick out after a good 30-40 minute drive and smell the oil. If it smells strongly like gasoline, you might have some fuel injector issues.
Don't use Lucas oil anything, go for either Redline SL-1 (fuel system cleaner) or Chevron Techron or whatever it's called. Those are the two best ones. I've used Redline with super good results on a car with around 70K. You will notice a huge difference with the way the engine runs... Will feel smoother.
Don't use the whole bottle at once. Run your tank to completely empty, add maybe half a bottle, fill up a quarter tank and drive to near empty again. You want a pretty strong concentration of fuel system cleaner, and you don't need alot of fuel for it to do it's work.
I would suggest (with a fully warmed up engine...!) doing some full throttle acceleration 1-3 times (preferably one after another in a short period of time, such as merging onto the highway) for maximum cleaning effect.
- Cold start exhaust smell- sweet-ish?
- Warm exhaust smell- none
- Oil color- amber brown, no milky
- Oil smell- I didn't smell anything, Boyfriend says it smells like gas
- Coolant reservoir- extremely low
- Engine temp- stable
- Heater- hot in 2 mins
- Wet spots- none, looked with flashlight
- Be very sure to top up your coolant reservoir with the same colour fluid as whatever it currently uses (clear coloured coolant , some distilled water or simply Lexus spec coolant will do just fine) make sure you regularly inspect the level and top up as needed.
- the smell of gas, especially if it's strong isn't good. Did you go for a quick drive before smelling the oil, or was after a good 30+ minute drive?
-Do you have any check engine light?
- Sweet smell = burning coolant. If you don't smell any gas that's good.
Checked the oil after a drive.
I didn't think it smelled strongly of gas but it sounds like even alittle smell could be a problem.
I have no check engine lights.
DWOU15
GS - 1st Gen (1993-1997)
26
04-27-11 10:27 AM
envyno1
Performance & Maintenance
03-15-08 08:33 PM
