headlight upgrade
https://www.xenondepot.com/D4S-autom...lbs-s/1043.htm
The Philips Xtreme vision and Osram Night Breaker will be brighter than the stock bulbs.
Replacement bulbs
I get all my bulbs from https://www.hidconcept.com/collections/d4s usually, really good pricing. I've tried the Osram Night Breaker Laser and the color was like OE around 4300K but much brighter I ended up just using Osram Cool Blue Advance its more like 5000K. I think because the factory projector lenses are frosted it alters the output. The brightness is similar but I want say NBL throws a little more than the CBA. I do want to try the Philips Xtreme Vision but I want clear lens swap my projectors first.
No. You just replace the bulbs on modern vehicles. The headlight housing only needs replacement after an accident or if heavily oxidized-clouded up beyond restoration. A new housing would be hundreds of dollars and you would still need a new bulb separate from the housing.
They are not one unit that is sealed and sold together. That stopped when sealed beam headlights stopped being used about 3 decades ago.
rickster9 (12-26-19)
rickster9 (12-29-19)
Max Power
06-20-11 07:23 AM
