ES 350 when accelerate it vibrates
my lexus es350 2007 194k miles when accelerate to 50 mph or more it vibrates a lot any one know what seems to be the problem
and any solution
thanks
and any solution
thanks
High miles. worn suspension components, loose lug nuts, likely something worn. Solution, too many possibilities for us to guess, take it to a trusted mechanic or a Toyota dealer (cheaper prices than Lexus for diagnosis).
So many things can cause it. Does the steering wheel vibrate also?
For example: Unbalanced wheels, warped rim or warped/damaged tires, loose/failing ball joints, loose/failing outer tie rod, wheel bearing, etc.
If you don't feel it in steering wheel, where DO you feel it??
Has to be seat-of-pants. Thus making rear end of car most probable location for problem.
First thing I would do is rotate front tires to rear. If you now have shake in steering wheel - it's bent rims or tire balance.
Have tire shop look at the tires and rims.
It is the CV axle mine is currently doing the same thing right now. My right side has to be replace . there very cheap great price and advance auto or auto zone had lifetime warranty .
