2008 es 350
How bad is the slipping? If yoy floor it from dead stop is it pegging the Rev limiter? Have you done a fluid change and also a filter change? If you haven't atleast done the fluid, I'd try that with a good quality trans fluid (Toyota ws specific). And also check your levels properly 104-113 in trans using tech steam
You can save it if the problem is due to old fluid. If your clutch packs are smoked then you're screwed.
Do a fluid flush/change and see if that helps.
I worked with a gal who had a 2008 Accord with 197,000 miles on it and her trans started slipping. I told her to go get the fluid "flushed" at the dealer. The slipping went away.
xnguyen002
ES - 5th Gen (2007-2012)
03-25-17 10:47 PM
