Suddenly Getting Three Codes C1201,P2197,P0174
Hi Friends,
while I began driving , the weather was on 45, the engine was cold, i suddenly got Check VSC message with traction orange light, Warning Red Color Sign and Check Engine light, when i went to advance auto parts, they gave me following codes
C1201,P2197,P0174
For your kind information: I had an accident from front that i got fixed last week, the parts i had to replace were Hood, enforcement, energy absorber, front bumper assembly, lights, condensor, radiator, smog sensor (USED), horns(used), and Right fender liner. the engine cover I have not replaced yet. however the car remained parked in collision center for three weeks before they fixed it. but since i got the car i have driven it more than 300 miles after which i got Check VSC message with traction orange light, Warning Red Color Sign and Check Engine light.
and yes i got front headlights replaced to halogen earlier they were HID, so body man had to change connectors using original harness lines.
looking for help and some DIY guidance. i am worried because of three codes together.
C1201,P2197,P0174
Hi Friends,
C1201,P2197,P0174
C1201,P2197,P0174
Hi Friends,
C1201,P2197,P0174
C1201,P2197,P0174
omerrkhann (02-29-20)
I am going to check for lose connections today, after which i am gonna reset and will update here.. however yesterday I just reset, car ran 35 miles fine withouth any check engine light, however, today's morning, i drove on high speed and it popped up check engine light and check VSC sign again... it gave me an idea that something is not supporting on high speed...
Some codes need to meet certain conditions before it goes off and a certain amount of key cycles.
hi friends,
I examined myself and found out that inlet Air Cleaner, (17752-31020) is lose and also there is gap in between intake line and inlet air cleaner (1775231020) although the car is in good shape since it was fixed last week , the hood is locking fine everything is aligned, i dont know why this OEM part is having gap between intake line, I am attaching the picture that will show the gap. also it is not fitting with inlet duct face line which is underneath of it. does this leak popup check engine light with CHECK VSC alert.. I remember last year when i changed the intake manifold gaskit and i forgot to put one of intake thin pipe that goes through sensor to intake that caused same CHECK VSC and check engine light issue and i only plugged it back and reset i didnt face any issues. i am wondering that if intake line leaks can cause check engine light and CHECK VSC alert too..
while trying to remove the mentioned gaps in the picture i have found that intake cover is broken.. secondly mechanic is saying since it was hit from front u also change intake manifold gasket he is saying broken intake cover wont alert the check engine light. but i doubt that there are clear air leak points in broken air intake cover... what do you think should i do...
I will take picture of 02 sensor / wiring too
