Cel and vsc p0356
Cel and vsc p0356
CEL AND VSC popped on while driving home from work
I through my bt scanner in pulled code and monitered for misfires, but all cylinders where coming up with a zero count
Update: coil was bad, I swapped 6 to 4 and code moved. But also found something interesting.. Found that most likely a squirrel took up residents in the car..
jd
jd
