Lowered 07 ES
VindiCated (06-22-20)
I've truly enjoyed mine and did not sacrifice ride quality at all. The set of coilovers I got came with front sway bar links but i would recommend swapping in moog sway bar links all the way around. The bc and the oem links design is not very well thought out, causes alot of trouble when it comes time to switch stuff out. I personally had to cut the old ones out. The design of the moog links is far better just a suggestion it'll save you quit a bit of time down the road.
The following 2 users liked this post by Alejandro0:
AndBrian89 (07-05-20),
i also plan on lowering my es on bc's, glad to know the camry coilovers fit on ours i've been worried. Thanks for the heads up with the moog sway bar links as well i'm also going to get them all around. I appreciate you and this thread
Did you also get the swift springs option that comes with the BCR coilovers? Im contemplating whether or not I want to spend an extra $320 on swift springs, because if the ride quality is already comfortable without it then im just not going to get the swift springs. I would jus like your opinion since you have experiences with the ride quality on these coilovers.
