ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
LED Interior Light Bulb Sizes
Old 06-04-20 | 10:12 PM
terror83's Avatar
terror83
Default LED Interior Light Bulb Sizes
I have 2011 ES350 and I want to replace all the standard interior and door mirror puddle light bulbs to LED.
Are the map lights, dome light, doors, trunk and mirror puddle lights all 168/194’s? And what size are the vanity mirror bulbs? I’ve researched but came up with a few different sizes so I just want to make sure before ordering.
Old 06-05-20 | 11:10 AM
ESh's Avatar
ESh
Puddle lights/door bottom lights are T10. For the interior lights I don't have that information because mine is 2007.
Old 06-07-20 | 06:20 PM
KMiles's Avatar
KMiles
https://www.automotivebulbfinder.com/philips/
Old 06-12-20 | 08:30 AM
terror83's Avatar
terror83
So I've replaced all the interior bulbs, door and mirror puddle light bulbs with 5000K 194 LED's.
But does anyone know the rear dome light bulb size? This is the only one that's not a 194 style bulb.
hresendiz2 (12-14-20)
Old 06-12-20 | 11:44 AM
nevernu's Avatar
nevernu
https://www.amazon.ca/s?k=2011+es350+dome+bulb&i=automotive&ref=nb_sb_noss https://www.amazon.ca/s?k=2011+es350+dome+bulb&i=automotive&ref=nb_sb_noss
maybe the first one
WLJH 31mm LED Festoon Bulb WLJH 31mm LED Festoon Bulb
is what you want?
Old 06-13-20 | 12:41 AM
terror83's Avatar
terror83
Originally Posted by nevernu
Looks like the OEM ones are about 27mm so I ordered a 29mm 5000K. That’s the only size I can find closest to OEM in that kelvin.
Now I have an issue where both front door courtesy/puddle lights don’t turn on when unlocking the car but they do turn on when the doors open. The rears work as they should with lighting up when the car is unlocked and the doors are open though.
Old 07-17-20 | 01:41 AM
Zaavan's Avatar
Zaavan
Can someone explain how to replace the map light into the center with the sunglasses compartment I don't want to break anything and I didnt see anything on YouTube.
Old 12-14-20 | 03:19 PM
hresendiz2's Avatar
hresendiz2
For the rear dome I could not find an exact size replacement for LEDs.
The closest I found at Autozone was the Sylvania DE3175 (They state it's also compatible with DE3021/DE3022)
I am attaching a few pictures, hopefully they get posted.
There's clearly a slight difference in length, but if you bend the thin plates of metal where the bulb seats, you can make it fit almost effortlessly.
Hope this helps someone
Funkdawg (06-29-21)
Old 12-14-20 | 03:24 PM
hresendiz2's Avatar
hresendiz2
These were hard for me. I almost broke the sunglass compartment with my disassembly attempt.
I googled on how to remove bulbs on tight spaces and they suggested duct tape.
It continued to slip on me, but it started to leave some glue residue on the bulb with every try and that's how I was able to remove those bulbs with just the fingers.
I am sure there should be a way to remove the entire dome enclosure, but I have not found anything yet.
krnboy817
ES - 6th Gen (2013-2018)
15
01-17-21 08:01 AM
Freds430
04-19-16 12:01 PM
rizzagt22
03-25-16 06:15 PM
Sssky330
CT 200h Model (2011-2017)
01-07-13 09:03 PM
terp05
01-13-06 11:12 AM
