2007 ES350 , High gas consumption within City
I have an es350 with about 75k miles on the odo, when I take it on the highway, the AVG consumption gives about 12-14L/100km
But when in town currently I am AVG 18L/100km
No check engine lights on, Lambda seems to be fine from live data 0.998-1.001
Any ideas on how I can get this car to take less fuel within the city, I actually tried not using AC for a while but seems thesame AVG consumption
Is there. Way of teaching the computer to learn how to save fuel
If your 2007 has the eco light (middle of tachometer), make sure you drive in a manner so that it is always lit. If the 2007 doesn't have the eco light, just drive like you have an egg between your foot and the accelerator peddle, and you don't want to crack it.
ChudiM (11-23-20)
I have not seen the eco light on mine, so what rpm range should I not exceed to simulate this egg between the foot and pedal analogy?
It's less about RPM, and more about how quickly you approach the necessary RPM for maintaining your speed. The more gradually you get to speed, the more fuel you will save. If you have a lead-foot and "floor it" all the time, you'll get your worst mileage possible. If you ease on the gas peddle most of the time, you'll get the best possible mileage.
No, wheel size is not a factor, but for many reasons you should keep the stock tire diameter when plus-sizing wheels.
Speaking of tires...make sure you keep your tires fully inflated to the specification called out on the driver's door jam as under-inflation will hurt your mileage.
ChudiM (11-24-20)
On my door plate stock spec is P215/55 R17 cold pressure @ 30psi
![](https://cimg5.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1250/screen_shot_2020_11_24_at_4_35_21_pm_b44a7f0b0c1b514be09435683c8b388176566f56.png)
ChudiM (11-25-20)
Air filter
Plugs
As a matter of urgency as it is. Driving more gently is a must now
i live in Canada and i get only 11 l/100km in -30 winters and 9l/100km in summer. I still go hard on the pedal once in awhile just for the joy of it. Remember to reset the computer by disconnecting the battery.
ChudiM (11-25-20)
Driving style
Tires / tire pressures
Winter fuels (winter fuels tend to not be as fuel efficient); Cold winter weather can also impact efficiency
Recent engine maintenance (plugs, coilpacks, air cleaner etc)
Excess weight (junk in the trunk)
All these play into your fuel efficiency
ChudiM (11-27-20)
Driving style
![](https://cimg3.ibsrv.net/gimg/www.clublexus.com-vbulletin/1080x1920/screenshot_20201127_105448_3fdd8c3853970be9a30955ff2b30b6a2a2168c2c.png)
![](https://cimg5.ibsrv.net/gimg/www.clublexus.com-vbulletin/1080x1920/screenshot_20201127_104828_bb4c387f4bdeafc1e27f0689da8aa429d332a719.png)
![](https://cimg6.ibsrv.net/gimg/www.clublexus.com-vbulletin/1080x1920/screenshot_20201127_105610_f504b072f3dd3e7ecf204e2b4fc600df18f936f6.png)
![](https://cimg7.ibsrv.net/gimg/www.clublexus.com-vbulletin/1080x1920/screenshot_20201127_105520_2dd5b7b4610b4d55b55ca94718962001342ab16c.png)
