2008 ES350 Sunroof drains / moisture issue
Where are they?
Best way to check and clean them out?
My car has the full glass roof option, so to be honest, I am not sure if its just the drains that could be at issue or if there are other seals that have shrunk or become less useful. I have noticed that after a heavy rain (car lives outside) in particular, my drivers side seat belt is sometimes damp. I think there must be a leak behind the interior trim that goes down the B pillar.
TIA
TIA
just read the drains usually run down A or B pillar. Look for a drain hose exiting bottom of car for clues. i've never noticed them myself.
check out link. its possible there are none. which would explain why there is a gap when the sunroof is closed. that gap always bugged me.
https://parts.autonationtoyotasoutha.../body--sunroof
If there are drains, and I suspect there are as the Camry has them, then use some weed wacker line to clean out the sunroof drains. Just push it through from the top and if it hits a clog try working it back and forth. You may have to find the bottom exit and push some through from the bottom too. The front ones are easy and are in each corner. The rears are harder to access. There are many youtube videos on cleaning sunroof drains.
See this https://www.cargurus.com/Cars/Discussion-t17823_ds36954
Good idea to try weed wacker line. Certainly don't want something so sharp that it punctures the drains. Compressed air might work too?
This link only shows drains for the traditional sunroof, not the panoramic glass roof that my car has. I poked around yesterday and I wonder if they only use "front" drains in the panoramic unit. I will need better lighting than I had to look more closely.
I did.. there were no mentions of drains.. At the top, with the conventional top, it mentions "drains, for non panoramic roof"; the bottom half shows the panoramic top and mostly the glass part numbers or the shade part numbers.
Finding the other thread, makes it sound like there are no drains (which is odd, cause if you had the roof tilted or open slightly and it started to rain, where would the water go?) It mentions that the water, at least when the top is closes, merely runs along the sides and uses the front and rear windshield paths along the external A and C pillars.
Be careful using compressed air on these low/no pressure drain lines. They are capable of being ruined by compressed air. I like the earlier suggestion of using weed-wacker line to clear a blockage.
These blockages are common and just one reason I wish sun/moon roofs weren't so prevalent. My wife and I never use ours, so it is an unnecessary maintenance headache for people like us. However, good luck finding a luxury car without one.
I said in post 2, its possible there are no drains. read/write more carefully for better help.
I would personally have somebody use a garden hose to spray down the car while you sit inside and observe. It could be your side window seals as well. Removing the B pillar trims shouldn't be too hard with some careful prying will give you a better idea of where the water is coming from.
