Salvage title
Just curious: Would anyone consider purchasing something like this?? I'm wondering if there is anyone who has had a good experience with a salvage titled car.
2012 ES350 Carfax
2012 ES350 Carfax
It will be very difficult to re-sell and you must have it inspected before considering purchasing it. I would not touch it as there are too many other nice ESs available.
To learn more about the damage, Call Pohanka Lexus
703-968-9100 and ask for the service department. Give them the VIN and ask what they know about the damage and repairs.
Here is what I pulled from Lexus Drivers
103621 MILESDATE: 06/2020
SERVICE:
DESCRIPTION: WATER CORROSION ON KICK PANELS 5.00 VEHICLE WOULD TURN ON OFF WHEN DROPPED OF BY CUSTOMER, HAD DIS ~|~CUSTOMER STATES VEHICLE HAD TO BE JUMP STARTED. CHECK AND ADVISE ~|~ ~|~103621 WATER CORROSION ON KICK PANELS 500 VEHICLE WOULD TURN ON OF...READ MOREWATER CORROSION ON KICK PANELS 5.00 VEHICLE WOULD TURN ON OFF WHEN DROPPED OF BY CUSTOMER, HAD DISACCORDING TO LEXUS NATIONAL SERVICE HISTORY. CURRENTLY NO OPEN RECALLS ON THIS VEHICLE AT THIS TIM ~|~ACCORDING TO LEXUS NATIONAL SERVICE HISTORY. CURRENTLY NO OPEN RECALLS ON THIS VEHICLE AT THIS TIME. ~|~ACCORDING TO LEXUS NATIONAL SERVICE HISTORY. CURRENTLY NO OPEN RECALLS ON THIS VEHICLE AT THIS TIM
SERVICE: COURTESY CAR FUEL AND CLEANING CHARGE IS $20.00 PER DAY
DESCRIPTION: COURTESY CAR FUEL AND CLEANING CHARGE IS $20.00 PER DAY ~|~LN 3488 PH 703-843-4507 COURTESY CAR FUEL AND CLEANING CHARGE IS $20.00 PER DAY ~|~
100312 MILESDATE: 05/2020
SERVICE:
DESCRIPTION: CHECK BELLY PUN AND FOUND FRONT BUMPER DAMAGED AND BELLY PUN RIGHT SIDE BROKEN NEED TO GO TO BODY ~|~CUSTOMER STATES BELLY PAN COVER IS HANGING. CHECK AND ADVISE ~|~ ~|~100312 CHECK BELLY PUN AND FOUND FRONT BUMPER DAMAGED AND BELLY PUN RIG...READ MORECHECK BELLY PUN AND FOUND FRONT BUMPER DAMAGED AND BELLY PUN RIGHT SIDE BROKEN NEED TO GO TO BODY
SERVICE: ADD WINDSHIELD WASHER SOLVENT
DESCRIPTION:
SERVICE: BALANCE FRONT TIRES
DESCRIPTION:
SERVICE: BG COOLANT EXCHANGE SERVICE
DESCRIPTION:
SERVICE: BG ETHANOL DEFENDER FUEL TREATMENT
DESCRIPTION:
SERVICE: BG MASS AIR FLOW SERVICE
DESCRIPTION:
SERVICE: BG MOA
DESCRIPTION:
SERVICE: COURTESY CAR FUEL AND CLEANING CHARGE IS $5.00 PER DAY
DESCRIPTION: COURTESY CAR FUEL AND CLEANING CHARGE IS $5.00 PER DAY ~|~LN 6322 PH 703-843-4507 ~|~
SERVICE: GLH-REPL PANEL AIRBAG - ES350
DESCRIPTION: GLH-REPL PANEL AIRBAG - ES350 ~|~SAFETY RECALL GLH - REMEDY NOTICE MULTIPLE MODELS AND MODEL YEARS TAKATA FRONT PASSENGER AIRBAG INFLATOR (ZONE B) ~|~PERFORMED GLH RECALL ~|~100312 280 VERIFY VEHICLE ELIGIBILITY BY CHECKING VIN IN THE TIS V...READ MORE
SERVICE: INSPECT FRONT AND REAR BRAKE PADS, CALIPERS AND ROTORS
DESCRIPTION:
SERVICE: INSPECT INSTALLATION OF DRIVER'S FLOOR MAT
DESCRIPTION:
SERVICE: MIDTRONICS BATTERY TEST
DESCRIPTION:
SERVICE: NEED SUN ROOF HOUSING AND CABLES
DESCRIPTION: NEED SUN ROOF HOUSING AND CABLES ~|~CUSTOMER STATES THE SUNROOF DOES NOT GO BACK. CHECK AND ADVISE ~|~ ~|~100312 NEED SUN ROOF HOUSING AND CABLES
SERVICE: PERFORM TRANSMISSION FLUID EXCHANGE SERVICE.
DESCRIPTION: PERFORM TRANSMISSION FLUID EXCHANGE SERVICE. ~|~PERFORM TRANSMISSION FLUID EXCHANGE SERVICE. CUSTOMER APPROVED ~|~ ~|~100312 220 PERFORM BG TRANS FLUID FLUSH
SERVICE: PROGRAM 1 MASTER KEY
DESCRIPTION: PROGRAM 1 MASTER KEY ~|~PROGRAM KEY ~|~ ~|~100312 50 PROGRAM 1 MASTER KEY
SERVICE: REPLACE BATTERY(S) IN MASTER KEY
DESCRIPTION:
SERVICE: REPLACE ENGINE OIL
DESCRIPTION:
SERVICE: REPLACE ENGINE OIL FILTER
DESCRIPTION:
SERVICE: RESET SERVICE INDICATOR
DESCRIPTION:
SERVICE: ROAD TEST
DESCRIPTION:
SERVICE: ROTATE TIRES
DESCRIPTION:
SERVICE: SERVICE - 100,000 MILES
DESCRIPTION: SERVICE - 100,000 MILES ~|~SERVICE - 100,000 MILES ~|~ ~|~100312 350 PERFORM 100K SERVICE ROTATE AND BALANCE 2 FRONT TIRE AND COOLANT FLUSH REPLACED OIL FILTER. CHANGED ENGINE OIL AND INSTALLED NEW CRUSH WASHER ON DRAIN PLUG. TORQUE DRAIN P...READ MORE
SERVICE:
SERVICE:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
SERVICE: BG MOA
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
SERVICE: ROAD TEST
DESCRIPTION:
DESCRIPTION:
The following 2 users liked this post by Clutchless:
Aimenlexi (12-24-20),
Riderdrumr (12-16-20)
Racerd (12-17-20)
Thanks for the answers!
2012 ES350 Carfax
2012 ES350 Carfax
- A salvage title makes for a smaller set of potential buyers when it is time to sell it because it scares many buyers
- Not all insurance companies will insure salvage titled vehicles
- Unless the person that repaired the vehicle is a trusted friend, you will probably never know the true story behind the repairs. If all it took was a new fender and paint, it would probably not be a salvage title. You should at least have a competent mechanic look it over for you. Sometimes shops will weld two halves of a car together: take a rear from a front collision & the front from a rear collision.
- There are many things that can be "off" depending upon what was destroyed and repaired
- Everyone probably has their own threshold for price too. If you are only saving a few thousand dollars, it is probably not justified financially.
I just Googled the VIN and found several things:
- It sold for $3,300 at an auction [https://en.bidfax.info/lexus/es/6003...c2473046.html]
- Listed at a dealer in VA for $10,950 [https://www.innovativeusedautos.com/...burg-va.shtml]. Based on other vehicles for sale, I would consider that a high price.
Good luck in your search.
The following 2 users liked this post by lexus997:
John U (12-18-20),
Riderdrumr (12-20-20)
Low Life
12-17-08 04:16 PM
MikeFD3S
09-28-06 10:46 AM
