best way to remove rear passenger weatherstrip window belt molding
can anyone tell me the best way to remove rear passenger weatherstrip window belt molding and where can I see a replacement? It seems that the rear passenger window molding does not align with the driver side due to broken clip. Thanks in advance.
maybe this will help for dismantle. on the possible broken clip issue check bluemoose window clip posts for replacement clip
https://www.clublexus.com/forums/es-...-pictures.html
socaligs (12-20-20)
is it possible to see the following:
34. REMOVE REAR DOOR FRONT WINDOW FRAME MOULDING
35. REMOVE REAR DOOR WINDOW FRAME MOULDING SUB-ASSEMBLY
Thank you!
Thank you!
i dont have any further details but I think that with the diagram of the pieces I enclosed it will be very apparent. I did both front doors/windows and it all came off easily. edit On looking at it further it seems that subassy piece is riveted in but do you really need to go that far to fix the weatherstripping...?
glassmanj
07-31-12 11:21 AM
