2009 Lexus ES 350 p0016
2009 Lexus ES 350 check engine light vsc light car running rough and different. code is p0016 PLEASE I NEED HELP is it something simple or something serious
Correlation means when the camshaft and the crankshaft are not following each other. It can be one of the sensors but it also can be a problem with the timing, that’s when the timing chain jumps a couple of teeth.
That can be really expensive to fix.
The other posibility is the VVT-i solenoid. It can be stuck because of the dirty oil or debris.
Hello and thank you for the reply also wanted to know the car turns on in the morning but after turning car off a few time when warmed up car will crank but not start it take a few try’s before it actually starts again if I turn it on in the morning and drive it all day without turning off it drives perfectly fine no problems at all does this have something to do with the crankshaft camshaft correlation code p0016
Dynasty30 (01-27-21)
The timing chain jumping a tooth or two is far less likely.
Thannp
01-31-21 10:10 PM
Curated Content Editor
ES - 6th Gen (2013-2018)
09-26-18 12:27 PM
