Oil Pan Drain Bolt Damaged
No sweat bro but how would you prove the car hasn't been anywhere else in it's 150k history? How would you be able to prove that you did not **** up the threads yourself, or your neighbor or etc?
I'm figuring that if you have a history of taking it to the dealer they're just gonna take care of you cuz you're a windfall to them. But what would you do if they declined to take care of you?
not everyone wants to DIY their oil, I get it. But if you can and willing, nobody else will do as good of a job as yourself. Its like that with many things in life.
tronimrich (02-04-21)
Yes, that particular drain bolt is designed with an o-ring there. See Smart-O drain plug (your brand may be different). It is not OEM, but it is a legit set up. I suspect whoever put that in is also responsible for cross-threading the threads.
It's like so much aftermarket innovative junk...if it was a good idea, it would have already been adopted by the auto manufacturers.
Hayk (02-21-21)
Will that O-ring style even work properly with the oil pan? The threads/bore of the drain is not that deep. I agree a solution to a problem that doesn't exist you can get a pack of 25 plug gaskets for $10.
Yes, according to the literature, the o-ring expands upon exposure to engine oil.
Personally, I've been using the light blue nylon gaskets for the past 35 years. See Dorman 097-116 for M12 size. They last 3-4 oil changes; I replace at 2 years or 30K, whichever comes first.
Wilson2000 (03-04-21)
I’ve bought 20 toyota OEM drain washer gaskets 6-7 years ago that I am still using and have not had any issues, granted that I also use torque wrench.
There is really no need to use non OEM
drain plugs.
drain plugs.
Always DIY if you can.
I have a package of washers too but they're not OEM. Got a package of 20 off Amazon for $8.
Agreed! My little brother got his first job at a Toyota dealer and worked his way up from lot-boy to the lube rack. He happens to be really good, but he was constantly harassed by his boss to take short cuts and even blatantly rip-off the customers! The horror stories are real!
It's not that techs at dealers DON'T **** up, but that they literally hold guarantees for their work. If you cna properly document your vehicle's maintenance history to point back to them as being the problem, you have recourse, whereas independent shops or yourself making mistakes leaves you out of luck
I've mentioned it in here before but i'll say my piece again
DIY is stressful too, not for the feint of heart, and not for those without skills, tools and experience. But, these things can be acquired. Those interested in learning can use sites likes this and YouTube to get up to speed.
tronimrich (03-13-21)
