2010 ES350 rear seats fold down
Does anyone know if the rear seats in the 2010 ES350 fold down? I tried looking at the owners manual and did some searches but was not able to find out if the rear seats fold down, or not. Thanks!
They don’t.
Yoo man it won’t let me message you ! But i have a 2010 Lexus rx350 with the po990 code on for the pressure switch number three circuit high, with the service awd and traction control light on, it’s has a used transmission recently put into the car through the warranty company , how can I fix this ? And do you know where I can get tech stream from ?
This should be in a new thread in the RX350 forum as it has nothing to do with the ES350 or seats.
Regarding your problems:
Take it back to the folks who installed the transmission. Your problems are caused by something they did or defective parts they installed.
Learn to search if you want to know more about Techstream.
The P0990 code is a generic powertrain code related to the transmission, including pressure faults and sensor failures. In this case, the transmission control module has received a higher than normal voltage signal from the transmission fluid pressure sensor/switch E.
Welcome to CL
GX - 2nd Gen (2010-2023)
1689
08-06-24 04:29 PM
