2010 ES350 Lights Help
2nd gear
I was wondering if there were any fifth-gen ES350 owners with aftermarket head and/or tail lights. I've been on the market for some, but I can seem to come across any at all
Also, I found some IS lights, but I'm not sure if they'd fit the ES models.
Any help would be greatly appreciated!
https://www.clublexus.com/forums/es-...eadlights.html
Hi Christine, you didn't specify if you were looking to replace the entire housings or just the bulbs for brighter and clearer lights. If you're just looking to upgrade your bulbs to LED for better lighting, I used the bulbs from here:
https://ledlightstreet.com/pages/sea...09+Lexus+ES350
So far I've replaced the low beams (H7), the high beams/DRLs (9005-same bulb for both functions), and the fog lights (9006). I also replaced the interior door lights & puddle lights with the 168 bulbs that are sold in pairs. For the head/fogs I used the Nimbis series...the ones in green on the site. The light is bright & clear and I couldn't be happier...as there are a LOT of crappy LED bulbs on the market, and these have been wonderful. Hope that helps!
Did you have to buy the decoder or did you just buy the bulbs?
thanks!
anonES
ES - 6th Gen (2013-2018)
03-29-21 12:22 PM
