Headlight (side light) replacement
Does anyone know how how to access the yellow light in the top picture? As you can see in the second picture that light is out and need to be replaced. Also, does anyone know the name or model number of the bulb needed?
cant remember if you can get at it from back directly but these pdfs will show where the bulb is and if u have to remove the bumper assy and headlight assy to get at it
nevernu (02-28-21)
P.s. I would recommend polishing your head light lenses with a standard compound (found at Canadian tire, Walmart or any detailing store). Meguiars Ultimate polish is a good option. If you do not have a rotary polisher, you can get great results with a microfiber towel and some elbow grease.
You have to turn the wheels to the right and then in the front of the wheel you will see a plastic cover, you remove the 3 10 mm bolts, remove the cover and you’ll be there.
Choccy
IS F (2008-2014)
03-04-21 08:17 AM
