I have an ES 350 2007 Lexus and I was wondering how much it would be to fix or replace a damaged bumper? It's only on the passenger side of the car and the light was not damaged. It's pretty bad, there is a dent and a hole in the bumper.
depends on how good you want it to look. you could probably bend that back enough to install it if you wanted. otherwise, it needs body work. front bumpers are relatively easy to remove and install. should be lots of videos on youtube that show how. all toyotas are similar.
Thanks for the reply! If I wanted body work do you have an estimate? I’m hoping it’s no more than 1k.
no clue. you could search junk yards online and see if one is available in same color/year. it won't match perfectly, but would save some money if you can do the install. who knows, only way you're gonna get an estimate is driving over to the shop. they need to see all what was damanged. may need braces, etc.
