Front end clunking
Front end clunking
Sorry for the new thread but I have replaced everything in the front trying to get rid of it and can't find out where its coming from,Any ideas?
things I've replaced are
struts
tie rod ends
rack and pinion
both cv axles
lower control arms
sway bar bushings
and I still have the clunk
struts
tie rod ends
rack and pinion
both cv axles
lower control arms
sway bar bushings
What about the strut mounts and sway bar links?
struts
tie rod ends
rack and pinion
both cv axles
lower control arms
sway bar bushings
struts
tie rod ends
rack and pinion
both cv axles
lower control arms
sway bar bushings
After that, I would inspect the u-joint connector for the steering column.
2GSTony
Suspension and Brakes
12-09-14 10:29 AM
