Interior Refresh
Just dropped off the wife’s car for it to be cleaned and detailed by a local company called AI Autoworks.
I used them to clean and detail then replace the headliner in a ‘03 VW Jetta I had for 17 years before selling it to a co-worker before buying another vehicle.
Looking forward to the end result later on today.
Funkdawg (06-23-21)
As for the carpet stains, rent a Rug Doctor from a home improvement or grocery store with the appropriate cleaner and anti-foaming chemicals. It does an amazing job on carpet stains. A drill brush or a regular stiff bristle brush would also help with pulling the dirt out.
Not sure if you’re up to this, but the seatbelt can be unbolted from the seat, pulled out of the car, and power washed or scrubbed by hand. I did that to mine and they look brand new. Looks like yours could use a clean.
Is it safe to remove seatbelts? Should the battery be disconnected? Will the seatbelts need to be properly torqued back? Or is it just a matter of unboltong, washing and installing back.
While mine are quite clean, I would prefer to soak them into a cleaner. Alternatively I may even entertain the idea of replacing the front seatbelts as they are quite worn.
Funkdawg (06-20-21)
I removed the interior trim pieces covering the seatbelt mechanism (B pillar) to get access to the part of the seatbelt that is otherwise inaccessible.
Also, disconnect the belt from the seat bottom not from the B pillar. The B pillar is where the pre-tensioner assembly is so it's much more difficult to remove that way.
Unbolt from the seat bottom and pull the belt all the way out.
![](https://cimg2.ibsrv.net/gimg/www.clublexus.com-vbulletin/1862x1492/screen_shot_2021_06_20_at_1_01_07_am_39a5f6d0c8b086d0dff38190f2256e01a2f6521b.png)
Here is the official wording from the repair manual:
Seat Belt Arming and Disarming
Wait at least 90 seconds after the engine switch is turned off and the negative (-) terminal cable is disconnected from the battery before starting the operation.
CAUTION:
* The vehicle is equipped with a Supplemental Restraint System (SRS). It consists of a driver airbag, front passenger airbag, driver side knee airbag, front passenger side knee airbag, front side airbag, rear side airbag, curtain shield airbag, front seat belt pretensioner, and rear seat belt pretensioner. Failure to carry out service operations in the correct sequence could cause the SRS to unexpectedly deploy during servicing, possibly leading to a serious accident. Furthermore, if a mistake is made when servicing the SRS, it is possible that the SRS may fail to operate when required. Before performing servicing (including removal or installation of parts, inspection or replacement), be sure to read the following items carefully, then follow the procedures exactly as indicated in the repair manual.
*(The SRS is equipped with a backup power source, so if work is started within 90 seconds after disconnecting the negative (-) terminal cable from the battery, the SRS may be deployed.)
CAUTION:
![](https://cimg7.ibsrv.net/gimg/www.clublexus.com-vbulletin/1010x1958/screen_shot_2021_06_20_at_12_54_43_am_eb6ea2e2c5e66587ba317c3106995e753ad62271.png)
Torque spec
Used a cleaner my wife had called "The Amazung Whip It".
Worked pretty good on the stubborn stains in the carpet.
The seatbelt, not so much.
Also tried Resolve carpet cleaner.
Hayk (06-21-21)
Bunz617
CT 200h Model (2011-2017)
06-14-21 04:39 PM
Nick@Autogeek
Club Lexus Vendor Marketplace
07-11-12 05:37 AM
AutoCoutureSC
SC400 / 300 Classifieds
22
04-26-06 04:05 PM
