Transmission Drain Plug ???
Question about the transmission drain plug. For those of you who do your own changes, can you advise if you have a metal washer or rubber one?
Have you read the thread regarding how to change your transmission fluid? IF not you better before starting this project because not only is there a drain plug that takes a 6mm allen wrench, inside the hole is an overflow plug of plastic that also takes a 6mm Allen wrench. https://www.clublexus.com/forums/es-...with-pics.html
ramram55
06-11-18 09:41 AM
Hgspine
RX - 1st Gen (1999-2003)
05-14-18 05:36 PM
