5th generation transmission "surge"
I have a 2007 (126k miles) and have been noticing as it's getting colder outside the transmission surges about twice (sometimes 3 times) a day usually from 2nd-3rd gear or 3rd-4th. Is this normal? I've already reset the TCM and changed fluid out.
I've noticed these transmissions can be buggy sometimes and once it gets stuck in a certain way of shifting it is like that for a few days.
Anyone else have issues when it gets cold? Once I've driven for about a half hour it's fine. But forget getting in this car and driving off on a cold start. Transmission is sluggish!
It's a known issue, take it to your mechanic/dealer for a software upgrade to fix it.
https://www.clublexus.com/forums/es-...350-tsibs.html
TC001-06: Auto Trans - 1,000 RPM 3-4 Shift Flare
TC004-06: Auto Trans - 3rd - 4th Gear Shift Flare
tronimrich (11-19-21)
[QUOTE=Robeconrad;11166781]I have a 2007 (126k miles) and have been noticing as it's getting colder outside the transmission surges about twice (sometimes 3 times) a day usually from 2nd-3rd gear or 3rd-4th. Is this normal? I've already reset the TCM and changed fluid out.
Anyone else have issues when it gets cold? Once I've driven for about a half hour it's fine. But forget getting in this car and driving off on a cold start. Transmission is sluggish![/QU
What color is your transmission fluid bright red, brown, or black in color? Is this the first time you have changed the fluid out and did you do a fluid flush? If this is your first fluid change out
I recommend doing another one if not you should be ok. I change my fluid every 30k on my using Max Life synthetic ATF and no problems with cold shifts.
dansandieg
RX - 1st Gen (1999-2003)
11-25-12 03:53 PM
