Transmission
3rd Gear
I have Lexus es350 2007 and it used to work perfectly last night I put it in reverse it won’t move but move forward. This morning when I put it in reverse it make one shift which you can notice before it can move and it shaking while reversing please anyone with solution.
3rd Gear
https://cartreatments.com/car-wont-go-in-reverse/
Most likely a valve body problem due to old worn out dirty fluid and lots of miles. A fluid change may help and is a relatively small investment.
Or if that does not work or is not possible,
Try to find a used transmission, then if you do find one, be sure to change the fluid during installation.
Or shop for another vehicle and sell yours for junk.
3rd Gear
I loved the way my 2008 ES drove on the highway, the engine power, and the quality and fit and finish of the materials and build. What I didn't like was the loud engine that made all kinds of noises, sounded like a race car, and the transmission. The earlier ES engines were soo quiet that you couldn't hear it running. I might look to get another Lexus, but if it has these kinds of problems, might as well get a Benz.
Mine had that problem after it was purchased 15 years ago. The shift solednoid for reverse was replaced.
Please scan it for the OBD codes.
chuyrobles (05-13-22)
I just changed the transmission valve body and I noticed that when I drive for a while then shift the gear selection into the reverse it will refused to reverse until I park the car, turn it off and allow it to cool for a while then turn it on again and put it into the reverse it will then move. So I want to know what the issue is, can you also tell me which of the solenoid it’s got the reverse so it can be changed. Please I will be looking forward to a quick response. This issue is causing me a lot especially financially.
LexusOnly7
GX - 1st Gen (2004-2009)
13
12-09-21 06:25 AM
