Air Cleaner/Box Cover Replacement
I accidentally broke one of the tabs on the air box cover while replacing my air filter and would like to get that replaced. I didn’t realize how big of a mistake I made until I found the Lexus price for that part! They sell it with a new MAF sensor included so it’s almost $400 and that’s not even the whole box. I need help finding a genuine replacement for a more reasonable price. My budget is around $200.
I looked on the eBay salvage market but received a really bad unit. The whole box was covered in oil, everything was soaked inside, and the hardware was very rusty!
My car is in excellent condition so Im looking for new genuine parts or a very lightly used one.
I figured out this box may be identical to other Toyota models such as the Venza which was in production for much longer than the 5th gen ES, so it should be easier to find low mileage examples.
Can somebody confirm if the Venza airbox is identical to the ES350? Found a VIN for a 2009 Venza on eBay and found this part number for the lid.
2009 Venza VIN: 4T3ZK11A39U008813
2009 Venza Air Cleaner Cover: 17705-AD016 $176
2010 ES350 VIN: Can be shared privately
2010 ES350 Air Cleaner Cover: 17705-31271 $373
If they’re truly identical, I’ll order a new one from Toyota. The only doubt I have is the Venza may not have the same inner filter built in.
Pictures of my ES350 for reference.
Those numbers don't cross reference almost always I find that if a part is identical then the number(s) will change up/cross reference. MAF is the same Lexus/Toyota. 17705-AD016 will be North American made Lexus part made in Japan that likely accounts for the price difference and possibly quality of part.
tl;dr: don't know if you can get away with the Toyota version.
These photos of a 2009 Venza engine bay look nearly identical to my car’s air intake.
Could very well be functionally identical I'd say there is a good chance it is. The OE supplier of that part is going to use the same tooling, molds etc. or maybe that's made by Toyota either way same applies. Why can't you clean up the used one you have and transfer over the metal bits?
Have you considered searching for local car junkyards that have Toyota's? Most of them will let you walk around and pull something like that, or have it already pulled.
Or contact Rancho Lexus Recycling
http://www.rancholexusrecycling.com/
I already returned it, it was complete junk. The built in filter was soaked in oil. If it was dry inside, I was considering what you suggested.
That’s true they have to keep it simple to keep costs down.
Our area doesn’t have pick and pull junk yards. I found one Toyota recycler but they only sell parts they removed themselves and they didn’t have any V6 models. Place was located in a very sketchy and run down town.
Something else that I thought of is maybe buying a cheap beat up airbox cover to use as a donor part for the broken tab, I could plastic weld the tab onto my airbox. Although I don't have the tools for plastic welding so the end result will probably cost around the same as a new part from Toyota.
I would never replace the cover because of that clip, I bet you any money the other group will hold it just fine.
Hmm that's not a bad idea. I could drill a small hole for a zip tie in the broken tab and loop it around the receiving end on the bottom half of the box. I may give it a shot if a replacement from Toyota doesn't work out, I like the idea of fixing it right if it's within my budget.
Hayk (06-21-22)
GS430FTW
1Gen RC350 / RC-F Classifieds
05-27-18 12:29 PM
