Loose xenon bulb in housing es350 2009
2nd gear
As the title states. I ended up replacing the xenon bulb in the passenger side but it isn't as tight/snug as it was before with the housing clips that you push to the side from the 11 and 1 oclock positions. Went in the same way and is now currently sitting loose inside the housing.
Any help/advice would be appreciated.
1. Try another bulb to see if it fits the same, swap sides. Make sure both bulbs are the same as your original.
2. Try bending the clips etc to get a tighter fit.
