Tesla style android display install 2011 Lexus ES 350
1st Gear
I just bought a Tesla Style Android display for my 2011 Lexus ES 350 from Alibaba (Autojeta store). It is a Navirider produced display. Because my car was purchased with built in Nav, I cannot install a standard double din display.
Does anyone have any experience in having one of these installed in SoCal? I tried BestBuy and after seeing the radio, they decided they would not take on the job. Who would you recommend I have install the unit?
You need an independent car audio store for this project. And probably a wire harness adapter as mentioned above.
Try the local chapters and regional forums section to try and find a local car audio shop. There is Southern CA chapter.
https://www.clublexus.com/forums/cl-...alifornia-149/
Here are stereo & audio search results from the So CA chapter.
https://www.clublexus.com/forums/sea...rchid=25654645
https://www.clublexus.com/forums/sea...rchid=25654646
I wont assume any responsibility for your build but I am not certain if that's really necessary. I was able to do it my self fairly easy once I had the correct wire harness. All the connectors are plug and play. Some ended up empty but thats just due to the variations in car trims. Finding the wire harness may be the more difficult part but you should check with the vendor you bought from if it didnt already come with a wire harness in the shipment. I would suspect it did. Its possible they sent the wrong wire harness though. I had that issue with my unit. They then charged me for the correct one, I am going to open a dispute once its all completed install for the money I paid for it. Any way, if you are in the LAish area I am an Santa Clarita so I am happy to help if I can.
