ES 350 Air Conditioning Problems
Ladies and Gentlemen,
My Bride's 2013 ES Air Conditioning compressor won't engage. The System is in Auto, Fan set to high, and temperature to Low. But compressor pulley is not turning. The car is in ECO mode. But that should not make any difference. We have had it for nearly 2 years and have always had it in ECO mode.
Do we have any Lexus HVAC gurus out there that can assist?
It is a screen from a car with navigation. Use Menu -> Climate to get there.
Look at post 88 on this thread on the RX350 forum as it describes the cheap magnet trick to get the compressor to engage. This is a common problem across the entire Lexus/Toyota line. The RX uses the same engine etc as the ES.
https://www.clublexus.com/forums/rx-...olution-6.html
You can also replace just that Sensor as the Dealer will not sell or do it. It actually can be tested by the Dealer for the Milliamp signal voltage. The sad thing is it not the Compressors, they are working fine when this happen, it's a $20 Flow Sensor on the compressor. I actually sent a letter to Lexus Corp and the SE Lexus Rep about this.
You can actually buy them from ebay. Part number 8831021150
It is a lot easier to stick a magnet on it. It is best approached from underneath.
NdYAG (05-22-23)
Thank you for the instruction. So Very Sorry to be so dense. We bought the ES used and it didn't come with a Owner's Manual. I have since found a 1400+ Page pdf Owner's manual and a Navigation manual. This should help tremendously. Thank you again.
