ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
How to fix driver's seat Wrinkles - Melting?
Old 10-18-23, 11:03 AM
MarkATL
10th Gear
MarkATL's Avatar
Default How to fix driver's seat Wrinkles - Melting?
So, the seat in my 2013 ES got some wrinkles and I tried to fix it with a steamer. Well, I think I didn’t let the material dry long enough before driving the car again. Now, it looks like the seat melted a little. Not sure if I can fix it or just need to go to an upholstery shop.
Thoughts?
Lexus seat.
Old 10-19-23, 07:07 AM
Tootsall
Tootsall's Avatar
Find a custom upholstery shop and have them replace the damaged panels. Not near as costly as replacing the seat or the seat cover with OEM parts. See this thread, posts #11 and #31.
https://www.clublexus.com/forums/ls-...-seat-dye.html
MarkATL (10-20-23)
Old 10-20-23, 08:35 AM
MarkATL
10th Gear
MarkATL's Avatar
Good idea and thanks for the info!
Old 10-25-23, 11:17 AM
MarkATL
10th Gear
MarkATL's Avatar
I found a local shop to fix it. The entire three panels will be replaced for $390. I looked at the material they will use vs. the Lexus factory material and it's 10x better than Lexus. And that's just sad. I was surprised just how thin the Lexus material is.
Tootsall (10-25-23)
Old 11-01-23, 03:19 PM
MarkATL
10th Gear
MarkATL's Avatar
I got the seat fixed and they did a fantastic job.
The following 3 users liked this post by MarkATL:
kramerica72 (11-04-23), shoodes (11-01-23), Tootsall (11-01-23)
Old 11-04-23, 07:33 AM
Bandura
9th Gear
Bandura's Avatar
It looks good. So they just replaced the 3 center panels? How's the color match on closer look? It looks a little lighter than the side panels, but barely noticeable.
Old 11-04-23, 02:11 PM
tolian21
tolian21's Avatar
I paid around $500 just to change seat bottom portion. Local upholstery, they used leather with 100% match to OEM, cant tell the difference in color or quality from OEM
Old 11-04-23, 03:47 PM
MarkATL
10th Gear
MarkATL's Avatar
They replaced the top two panels. They look like three panels but one is separated by stitching. The color match looks off because of the lighting but it is a perfect match.
Can’t believe how thin the original Lexus seat material is. Almost cheap.
Old 12-13-23, 01:05 AM
samsonn25
samsonn25's Avatar
Saw this versus buying a used seat for $150-300
Old 12-13-23, 12:07 PM
MarkATL
10th Gear
MarkATL's Avatar
Used seat price plus $250 S&H.
Old 12-18-23, 08:49 AM
samsonn25
samsonn25's Avatar
Depends where you go car-part have alot daily
Old 12-18-23, 03:03 PM
MarkATL
10th Gear
MarkATL's Avatar
Huh? What’s the point of your replies?
Old 12-18-23, 05:02 PM
samsonn25
samsonn25's Avatar
That means you can have another entire seat for same price as fix one, and you can sell the old one for $100-200 to make your cost down to $50
Kenasch
NX - 2nd Gen (2022-current)
04-03-23 09:07 AM
Truly55
RX - 4th Gen (2016-2022)
10-25-20 12:36 PM
IsdiorFlow
12-11-10 03:37 PM
Coolpop
03-26-10 04:24 PM
Integrator
01-21-03 12:35 AM
Quick Reply: How to fix driver's seat Wrinkles - Melting?
