plate sub-assy fuel replacement
3rd Gear
My ES300H has over 60,000 miles on it and my dealer said it needs 60,000 miles maintenance.
Dealer says plate sub-assy, fuel (part number 77024-33142) needs to be replaced.
Is this really necessary at 60,000 miles?
What did they say was the reason?
3rd Gear
That's in the fuel tank why replace it? Maybe the part number is a mistake? Unless that part is being recalled or some other defect I would never go back to that dealer.
Toyota Lexus has major issues with certain model and fuel pump parts runs. Unless they tested the pump or you had a problem I would not replace it. Also ask them under the "Fuel Pump" recall is your Vin covered?
https://www.consumerreports.org/cars...y-a1016833979/
On the other things I always advise that a good rated Toyota dealers service dept can do the same services for give or take 35% less than Lexus.
- Brake fluid - maybe
- Transmission fluid - can easily wait till ~120k on eCVT (it's just gears splashing in oil, no clutches, no solenoids, all fluid is 100% replaced in one go). I have replaced mine at 120k and it looked good.
- Spark plugs - can wait till 120k as recommended by Lexus
- Fuel filter (including plate subassembly) - never needs replacing
The fuel filter in the tank is good to be replaced but not before 100-120K. Just a waste of time and money.
orZift
GX - 2nd Gen (2010-2023)
12-25-22 08:47 AM
