2016 ES300h Radio Replacement
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
Hey guys,
I just bought my es300h couple of weeks ago and I'm loving it so far. One thing is I need to fix the radio and I am a little confused on what radio unit I need to buy. The face ID says its a 100478 however, I can't seem to find that anywhere online, however I do see 100476 ID, and it has the same lay out as well, with the navigation and SD card slot. Would I be ok to use the 100476 radio ID or do I need to find a 100478? Thank you.
I see a radio ID of 100476 but my search results comes nothing for 100478. (All this based on google)
2016-2018 Lexus ES got the newer generation headunit compared to the 2013-2015. Theres a drastic difference in the UI and probably hardware wise too. Not sure if they are interchangeable though
Whats wrong with your current headunit?
Hmm ok, cause design wise, everything seemed to match so was maybe thinking it can be used interchangeably
The problem I currently have is that the screen doesn't turn on except when I'm in reverse then the back up camera shows otherwise it's just blank, A/C display turns off when lights turn on and USB/aux port don't seem to work either
baneling
NX - 2nd Gen (2022-current)
03-05-24 07:02 PM
