ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
Debadging the 2013 ES
Old 12-28-12, 08:40 AM
mrBillFL
mrBillFL's Avatar
this is on my to do list... should be high 70's this weekend.
Old 12-28-12, 08:57 AM
KennyLexus
KennyLexus's Avatar
I too will most definitely debadge once the weather warms up. I did it on my Audi leaving the 4-rings...it looked great.
Old 12-28-12, 11:52 AM
jfz219
jfz219's Avatar
The hair dryer is a great way to remove the badges in all seasons. With a little patience they can be removed, stored in a plastic ziplock bag, and reused. no need to wait until warm weather.
P.S. I like the look of our RX350 rebadged and without roof rails.
Old 07-28-13, 06:02 PM
montyf
10th Gear
montyf's Avatar
OK, I'm ready remove my "hybrid" door panel badges.
I worked some dental floss down the backside and felt it cutting away at the adhesive.
Am I correct that when I'm done the badge will come off and there will not be any
unsightly blemishes underneath? Will there be gunk I need to soak off?
thanks for the help and words of wisdom
Great car and hoping to get it more trim looking without the emblems.
Old 07-28-13, 07:28 PM
mrBillFL
mrBillFL's Avatar
I decided to leave mine on for the HOV police.
but the dental floss will cut the tape, and the metal badge come off, Then you need to remove the tape from the car, with goof off, or some other method.
Old 08-05-13, 07:52 AM
Frank1934
Frank1934's Avatar
Default No pins
I just used a hair dryer to warm it up a bit and then just using a fingernail it came off fine
Old 08-25-13, 05:37 AM
RazSrq
RazSrq's Avatar
I debadged my ES last week. My dealer had to special order my UL, so it was just shipped over. I found that the adhesive was not completely set yet and the badging came off much easier than expected. Some popped off as I carefully pulled up while going left to right with the fishing line.
I did use a blow dryer to warm up each letter/number and wiggled them a bit before running the fishing line behind them (one at a time). I used 15 lb test fishing line, which worked perfectly. I did use the 3M Adhesive Remover (safe for painted surfaces) without a problem, but that is a personal choice. Lastly, I also utilize a small, very bright shop light to highlight the specific area and paint while I did the work.
Out of all of the vids I watched, this one was most helpful:
Youtube: How To De-badge a Vehicle by rtlGarage
Old 08-25-13, 07:20 AM
oneor11
oneor11's Avatar
Thanks for the posting the video. That is helpful. Your car looks sharp man.
Old 04-15-14, 06:28 PM
Max707
Max707's Avatar
That was easy, only took about 5 minutes. Wife's hair dryer and some waxed dental floss. Emblems and adhesive came right off. Then a little wax to polish everything up. It was 60 degrees and I had the garage door open.
Old 05-03-14, 03:43 PM
Mhobizal
Mhobizal's Avatar
Thanks for the info in this thread! Used a hair dryer, small plastic gap expander (received from ProClip for my cell phone mount) and orange Glu Gone. Removed my Hybrid sticker from the sides of my ES300h.
Don't forget to wax the area after you are done!
Old 05-04-14, 05:07 AM
steig
steig's Avatar
Removed my Hybrid Emblems a while back. Very easy to do, hair dryer, fishing line, and some wax.
Old 09-03-17, 07:07 PM
Yegorm
Yegorm's Avatar
Default 2007 es350
http://youtu.be/5saNP7cdFck
So does a 2007 es350 have holes underneath the badges? Im curious
Old 09-04-17, 04:00 AM
GES
GES's Avatar
You posted this on the 6 Gen ES forum. You may want to post it again on the 5 GEN ES forum.
LTU-Lexus
11-09-09 12:42 PM
XenonES3
07-24-03 10:04 AM
Bluesman
05-04-03 12:36 AM
TheBigGuyRy
15
05-14-02 03:12 PM
ramsee1
09-05-01 01:04 PM
Quick Reply: Debadging the 2013 ES
