ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
Mark Levinson Audio?
Old 04-04-13, 11:53 AM
  #196
Robdog1515
Robdog1515's Avatar
Need feedback.
If I were to take the stock 8"sub out which is a downfiring sub into the trunk, and replace it with a standard 8" sub that fired up into the car, would the acoustics and air vibrate the heck out of the rear of my car? Or is it best to stick with a down firing shallow mount 8" sub? Does anyone know the RMS output of the mark levinson amp for the sub channel? And I am assuming the speaker is a standard 4Ohm speaker, has anyone measured theirs when it was not connected to the amp? If I replace my sub on my own I want to make sure I closely match the rating of the old sub so I don't over draw the amp.
Thanks for your help.
Last time I spoke to harman regarding this issue, it sis not appear that they were eager to come out with a good solution to our problem.
Old 04-04-13, 12:37 PM
  #197
LexRuger
LexRuger's Avatar
Originally Posted by Robdog1515
Need feedback.
If I were you, I'd just get something like this
http://www.crutchfield.com/p_236RT8P...PT.html?tp=114
Built in amp, doesn't take up a lot of space. Then when Lexus does come out with a fix, you could just disconnect it and they will never know it was there.
Old 04-04-13, 03:19 PM
  #198
ICnothing
ICnothing's Avatar
At the rate Lexus and Harman are going to resolve this issue, we will all be looking for a new car because ours are to old.
Old 04-04-13, 05:32 PM
  #199
Music4ever
Music4ever's Avatar
Hey TPatel where did you get your vehicle fixed, and who was the service advisor? Have you played music with a lot of base to make sure? Can it be possible ths is the fix, hope so.
Old 04-04-13, 06:04 PM
  #200
Mike728
Mike728's Avatar
300h? I think a poll is in order for this issue. I have no idea how this is set up in the hybrid. Is the down firing sub still visible in the trunk, or do the batteries block it?
Old 04-04-13, 06:39 PM
  #201
Music4ever
Music4ever's Avatar
I believe the batteries block it.
Old 04-05-13, 05:39 AM
  #202
Mike728
Mike728's Avatar
If that's the case, that would be a problem.
Old 04-05-13, 06:42 AM
  #203
tpatel12
tpatel12's Avatar
The sub is still visible in the trunk and I do not think the setup is different.
Old 04-05-13, 06:50 AM
  #204
tpatel12
tpatel12's Avatar
I have tested it with bass heavy songs at a high volume ( above 40 ). Before the sub would distort and now it sounds great.
Ask for the service manager
Bredemann Lexus
2000 Waukegan Rd Glenview, IL 60025
(847) 510-5535
Old 04-05-13, 07:10 AM
  #205
Mike728
Mike728's Avatar
I think the setup needs to be different in the 300h, vs the 350. I'm glad to hear the sub is visible, but the tuning of it should be adjusted for the different overall cavity volume.
Old 04-05-13, 07:11 AM
  #206
Music4ever
Music4ever's Avatar
Thanks TPatel, I will have the dealership call Bredemann Lexus, it is appreciated. Hope this solve my issue and everyone that is having the same problem...
Old 04-05-13, 07:33 AM
  #207
bobsobi
bobsobi's Avatar
I think cabinet volume size affects low frequency response a lot more for really small enclosures, much smaller than car trunks! The difference in trunk volume between the 350 and the 300h won't move the woofer's resonant frequency so much to be that noticeable, especially considering the apparent amount of care Harman Becker put into the ES ML's tuning.
Old 04-05-13, 07:42 AM
  #208
Mike728
Mike728's Avatar
Maybe not the size, so much, as the shape and distance to the nearest reflective object.
Old 04-05-13, 08:26 AM
  #209
bobsobi
bobsobi's Avatar
Reflections are a concern on the listening side of a speaker system. When you're talking wavelengths of 10 to 60 feet (roughly 20 to 100 Hz), there are no reflections in an acoustic suspension enclosure (the trunk).
Old 04-05-13, 09:03 AM
  #210
Mike728
Mike728's Avatar
That would apply to a high frequencies. When you're talking wavelengths of 10 to 60 feet (roughly 20 to 100 Hz), there are no reflections in an acoustic suspension enclosure (the trunk).
Then we're back at the enclosure dynamics. Do you agree density can have an affect? I'm sure the batteries are more dense than the empty trunk enclosure. Ever heard the effects on bass in a concrete basement, vs. an open framed room?
Quick Reply: Mark Levinson Audio?
