Any Techies Out There That Kow Recording Music On A DVD?
OK - see if you can follow this equation and tell me what I am doing wrong:
1) I have blank DVDs
2) I can take a pre-recorded DVD and it will play in the ES300h
3) I can take a blank DVD and record music from a playlist (within ITunes) and then play it back on my computer and it shows the music is there.
4) But when I take that same DVD and try to play it in the car - it says "no music found".
I think the problem lies within Itunes (but obviously not sure) - because when I put a blank DVD in the computer to burn the playlist - I get a note stating something like "you have inserted a DVD and not a CD and have chosen to record data". That's not the exact wording but that is the gist of it.
Is there any way to record music in MP3 format upon a DVD that will then play in my car?
JerryKK, I have tried just that and found the same thing, the car will not see the mp3 files on the DVD. When a DVD is inserted, it is looking for the format that DVD movies are in. I have found one program that will convert mp3 music files into a DVD movie. The program that I have used with success is Roxio Music Lab 10 Premier.
From their website http://www.roxio.com/enu/products/re.../overview.html
Create AutoMixes - Create DVD Music discs with up to 50 hours of music on a single disc and smart navigation to make it easy to find songs and playlists.
Why not just put the MP3s on a thumb drive, plug it into the USB port, and play them from there? Probably a lot faster than recording a DVD and using the proper software to make it readable by the system...
Jetman - yes, that was my alternative to getting the music into the car. The problem is that I am using Itunes - and while I have burned CDs before I have never moved music onto a flash drive. Is there a quick and easy way to do that?
Thanks
If you have a Mac, click and highlight the music you want in iTunes, then drag it onto the flash drive. However, the lexus may not be able to read music that was purchased from the iTunes music store since it is not an mp3
I actually have a PC - and all tunes are downloaded from my own CDs.
The player in the ES300h/ES350 is a DVD player, so I believe you can only play DVDs in it (or regular music CDs of course).
You have a couple of choices. You can invest in an inexpensive DVD recorder and record to it (I record Direct TV music channels which are commercial and announcer free onto DVDs) or get video editing software for your computer and record a DVD with your music tracks that are on your computer. Depending on the equipment you have, you can record up to 8 hours (perhaps even more) of music.
I have not tried this, however i think you should be able to use export feature of itunes. I usually copy entire directory over to usb and plugin usb drive in car.
MP3's from thumb drive
I loaded all my CDs in Itunes. Converted all those MP4 files to MP3. Made folders for each album on my thumb drive and just copied the files to the appropriate folder. Keep the thumb drive plugged into my USB port - works great .
JeffO
GX - 1st Gen (2003-2009)
11-05-09 12:24 PM
