Thumping Noise from Mark Levinson speaker / subwoofer
Lexus contacted me with another fix that I hope will be the solution. They have yet another redesigned amp that should be in by Monday or Tuesday. I'll keep you guys updated.
Most of my music i play is from iTunes, and I am having the Same problem with the poor quality sound. One song that accrues around the 40 volume tone is suit &tie by Justin Timberlake and it played amazing on my 2008 GS 450h ML. So to Mike 728 Comment i do believe this is a big problem and only on the ES models, but it does depend what music you listen to, not only XM As Mike 728 indicated. Thank you -khatieh for keeping us updated and your comments please let us know how the new amp works.
I initially thought people were complaining of the sound quality while listening to XM, which will never sound great. It now appears to be all sources for those with the issue, so I'm now enlightened. I also want to stress the importance, for those who haven't purchased yet, of bringing a quality reference CD with you on your test drives. From what I've read, the issue is there from day one on the affected systems.
I had the same issues. Took my car into the dealership 3 times. The 3rd time the service technician noticed that the surround sound for the ML system was set to on. Unless you are playing a DVD, the system should have Surround Sound set to OFF. Once I changed my surround sound setting back to OFF, the subwoofer started delivering bass the way I had anticipated it would when I first bought the car. Sounds great now! Problem solved!
2013 ES350 UL
2013 ES350 UL
All my music is atheist 320 kb/s
Lexus installed the second revised amp and for the most part the problem is " resolved". I said it like that because I think they just reduced the gain until the subwoofer didn't distort which I think is a cheap fix and is not fair to us. I can still get it to distort if my bass setting is higher than 2 or 3 notches up. In my 2013 RX mark levinson, I can put the bass all the way up if I wanted to and put the volume up and it sounds crisp and clear with no distortion. I am very disappointed with Lexus on this issue and do not feel like I am dealing with a luxury company. Idk where to go from here.
If you have to turn the bass up higher than 2, or 3 notches above center, something's not right with your recording.
Why would you say that, there is a reason why there are equalizers, for different tastes in music. Most my digital music is from itunes, and the rest of the music I listen to is from CD's. There is nothing wrong with my recordings.
Outbound EQ's should be used for environment tweaks, not adding something that isn't there. One of the reasons the ML costs so much more, is it's already optimized for the listening environment in each car it's installed in. A lot of engineering time went into setting it up and getting it as close to flat across the audible frequency spectrum as possible. Think of this like paying someone to come and do an ISF calibration on your home theater screen, and then changing the sharpness after the tech leaves because you like the picture more vivid. To each his own, but I like my music the way it was meant to be heard.
I will agree Mark Levenson does cost more, but on the 2013 ES the sound it poor, at the end of the day they stamp there name on the product and should be helping to fix the issue but they have not as indicated in another thread. I Have been waiting for 3 weeks and e-mailing Harman and Uniter Radio at least once a week and no response, and Lexus just contacted me on Thursday and claims to know nothing about this issue and will investigate...What a load of ******. If people have been complainng how can they say they have not heard of this issue. I did shout off the surround sound it still not responding properly, the sub cannot take the base.
I just thought of something. Is anyone with an ES350 complaining of this issue, or just the ES300 owners? I guess I didn't take that into consideration. Looking back through the threads, it appears to be the 300's are complaining the most. I have no experience in the hybrid, so maybe the batteries in the trunk are causing some acoustic anomaly.
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
I have the ES 300h , and I actually do have a home theater with very high end speakers (Martin Logan) and Macintosh Pre-Amps and Amps. I set it up and calibrate it my self and use the same iPod I play in my car, I don't have an issue. That is a good point though, the hybrid battery could play some part in the problem. Who knows, I wish I could take a look myself without voiding my warranty.
I just thought of something. Is anyone with an ES350 complaining of this issue, or just the ES300 owners? I guess I didn't take that into consideration. Looking back through the threads, it appears to be the 300's are complaining the most. I have no experience in the hybrid, so maybe the batteries in the trunk are causing some acoustic anomaly. ![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
