Clear patches around the lower rear wheel well
[QUOTE=alpinefun;8469248]The bottom 16 inches or so of the fender/rear quarter panel are actually an extension of the bumper that raps around to the sides of the vehicle and forms the rear portion of the wheel well. You can confirm that this is the case either visually or by gently tapping on panel and hearing the sound you would expect to get from tapping on the material that the bumper cover is made of. This has become a part of the design of many, perhaps most, vehicles in recent years since the auto manufacturers stopped using chrome bumpers. In the case of many low speed rear end collisions, I believe that this design can help to limit the damage to the bumper cover and reduce the chance that there will be damage to the sheet metal on the sides of the vehicle. On the other hand, the downside of this design is that, if the bumper is damaged and a new bumper cover needs to be painted, getting a satisfactory paint match with many colors is likely to require blending the new paint into the sheet metal adjacent to the extended bumper on both sides of the vehicle.
Notice that, in a similar fashion, the front bumper cover wraps around to both sides of the vehicle and forms the front portion of the front wheel wells.
I did the same thing- the plastic patches were really bugging me. Could not get the edges clean, and as a result they didn't look good against Starfire Pearl.
I love the look now but will monitor this area and report back if problems. I know that the area is now vulnerable to road debris, but for me it's a risk worth taking...
Steve
Six months and 7,000 miles later and not one nick since removing the clear patches.
I washed and waxed every nook and cranny on my car yesterday getting it ready for winter and was happy to find no damage in this area.
Yeah, that damage usually occurs during the winter months around here. They lay salt for the first few storms, then mix it with sand when they determine their salt levels are running scarce. The sand, by far, causes more damage to areas that the wheels kick debris up on. Good luck!
A good way to check to see which areas of the vehicle are most vulnerable to damage from stones and other debris is to see, right after washing the car, which parts of the car are the first to pick up dirt/mud from driving on slightly damp roads because small stones will likely be hit the vehicle in the same spots where dirt/mud will strike the vehicle. With the ES, I've noticed that the first areas to pick up splashes of dirt and mud after the car has been washed are, in fact, the spots in front of the rear wheel wells where the Lexus puts the protective clear film. So, I give Lexus engineers credit for figuring out that those spots on the vehicle are in need of protection.
Similarly, you can get an idea of which areas on the front of the vehicle are most vulnerable to stone nicks by seeing where bugs get smashed onto the nose and hood. The same areas where bugs are carried up onto the vehicle and splash on the body panels are the same spots where stones are more likely to be carried up to where they strike the vehicle and end up creating stone nicks.
Some roads I have to travel in rural areas are not paved and have a loose gravel surface, so there is a steady stream of small rocks impacting the exposed areas. Glad Lexus added the clear protection. You can tell which vehicles are local by the sand blasted areas behind the wheels. Some bare areas aren't even rusty as the gravel keeps it clean
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
dendenyc
12-28-15 05:27 AM
