Tpms ??
Hello All ! New to ClubLexus Forum.
I recently added new 20" rims, tires and new TPMS (kept factory TPMS on factory rims and tires in case i need to swap them). Ive been to many big tire companies to get the new TPMS activated on my 2013 Lexus ES 350, for some reason they can activate them and no more amber exclamation mark in parenthesis but cant get the psi to show up on the OBD. I have the pic of my car on the dash plus 3 dashes next to each wheel. I spoke to the Oro-Tek technicians and say they should have shown up on the dash when activated. Anyone else experience this issue or have any suggestions. TIA
make sure that they have the latest version of the OBD TPMS software. It has to be updated for the 2013 models. I was trying to have a second set of TPMS programmed for a winter set of tires, and even Lexus couldn't get it to work until they discovered there was a software update.
I also discovered during this process that the '13 es only has room for one set of TPMS codes at a time, instead of 2 like the older models.
I went to Ted Weins, at first my sensors wouldnt show up for the car. So after they did a software update they were able to pick up the sensors with their tool and program each sensor and then plug into the OBD sensor and it said it was programmed, and the light went off. But still not showing up on dash display. Im fine with having only one set programmed at a time. I live in Vegas so i dont have to constanty change my tires. My reason is if i ever sale my car i want to keep my stock parts in case i need to swap them out or if im going on a road trip.
