Dealer programmed settings
Jonmanch, assuming we're talking about 2014 models, that's simply incorrect. Look at #28 on this document:
http://www.lexus.com/pdf/service/ES_LPS.pdf
And you'll see it's disabled by default.
I also have a 2013, and the pdf for 2013 personalized settings shows the default for that setting to be "off", just like it is for the 2014 model year.
See #29 of pdf for 2013 ES300h personalized settings. Also note that default for this setting for the 2013 ES300h is the same as for the 2013 ES350.
http://www.lexus.com/pdf/service/13E...i-customer.pdf (for 2013 ES300h)
http://www.lexus.com/pdf/service/ES_LPS.pdf (for 2013 ES350)
I also confirmed that the default is "off" by checking my own vehicle. On that vehicle, no changes have been made from defaults, and the windows do not open with holding the unlock button for several seconds.
Hi guys, I just wanted to let you know that you now have another option too: use the Carista OBD2 app for Android to change your settings by yourself. Being the developer of that app, I'm definitely biased, but I'd say that it's a lot simpler to use than Techstream (there's no setup/driver install needed) and it doesn't need a laptop or wired cables at all: it just runs on your phone or tablet and connects wirelessly via Bluetooth (you do need an ELM327 bluetooth device though - but it's cheap).
See http://www.caristaapp.com/2014/03/04...-with-carista/
When I read the app description on the Android App Store, it says that it will work on most 2005 and later vehicles. When I read the description linked to in your post, it says that it will work on the 2010 and later Lexus GX. Is there any chance that it will work with the Generation 1 GX (2004-2009)? If not, do you have a similar app available that will work with a Generation 1 GX?
The app looks like a useful tool.
For now we don't support the 1st gen GX because it uses an older communication protocol. We only support the newer models that use "CAN". But we are looking into adding support for that older protocol - so far it seems doable with the same ELM327 hardware. If we do add support for it, it'll be available as a free update to the app... but no promises that we'll be able to do it at all!
Our salesman printed out the five pages of Lexus Personalized Settings for us when our car was delivered. We know what can be changed and check it off on the list and @ the 5000 mile scheduled maintenance service they will set it.
Now we just need to drive it more, only 2000 miles since 12/2013.
I'll be looking forward to seeing your evaluation. If the app would also work with my GX, I would buy it now and order the Bluetooth device. I may do so eventually regardless of whether there is an update that will make it compatible with the GX, but, in the mean time, I still have the Techstream available to me to use if I need it.
The remote window and sunroof open was set on prior to the keyless fobs and are now defaulted off.
The related feature is the closing of any/all openings by inserting the mechanical key in the drivers door
lock cylinder and turning counter-clockwise. Was on with previous keys now off on the "hidden key" style.
While it would be extra cool if we could not only remote open the car but also remote close it, apparently
while the openings are "jam-proof" when auto closing (finger not holding the button) they will close relentlessly
if held. To "hold" the remote switch while perhaps out of sight of the window/sunroof might cause problems.
By the way, we've just released a new beta version of Carista with even more settings available
What I would change close to the end of the 4 year and or 50k warranty is the driver seat auto slide back and the auto steering wheel up. If the motor wears out after the warranty that would cost !! I will probably have that option changed now since I don't need that to happen. Not a fat guy
What I would change close to the end of the 4 year and or 50k warranty is the driver seat auto slide back and the auto steering wheel up. If the motor wears out after the warranty that would cost !! I will probably have that option changed now since I don't need that to happen. Not a fat guy ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
