Power accessory outlets
It is on the back (outside) of the console below the air vents for the rear seat. It has a plastic cover over it.
The ES rear outlet labeled 120 watts and 10 amps. I presume the front is the same since they both have 15 amp fuses. If you do the math 12volts x 15amps is 180 watts max.
I expect your 300 watt inverter rating is output so the input power would be even more, meaning it will likely blow the fuses and not work with your standard outlets if it is fully loaded.
Thanks! Does anyone know the max alternator output? I would hope cars these days have a little more power alternator, considering how much electronics are in there.
Sit in the back seat. Look at the center console, below the air vents.
Again, thanks guys!!!
