ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
ES 350 With IS Wheels
Old 11-06-14, 09:01 AM
MadMax96
MadMax96's Avatar
Originally Posted by mspearl95
Wheels/tires look too small for the car.
Like the wheels, but with those tires it looks a little off.
As mentioned - it's not so much the diameter of the rim, it's the outside diameter of the tire that matters.
I've seen tire/wheel calculators online where you punch in the wheel size and tire size and it'll tell you the overall size. There was one out there that allowed you to compare 2 setups so you can see the different in size and percentage.
You don't want to throw it off too much otherwise your speedo will read wrong and you might possibly accumulate more miles on the odo than you have actually driven.
Personally I'd find the proper tire for the wheels and then sell off the tires.
Old 11-06-14, 09:13 AM
Received 2,751 Likes on 1,968 Posts
It would look great with taller sidewall tires, as it is the wheels look too small on the car and I'm not digging it.
What everybody has said about the speedometer is very true also.
Old 11-06-14, 11:40 AM
mspearl95
mspearl95's Avatar
I agree. I like the wheels too. I think 225/55/17 is the proper 17" tire size for the ES?
Old 11-06-14, 11:46 AM
josmat
josmat's Avatar
Lesz.... Im using an 18 in wheel now. I used a 17 before. The tire is smaller ( for now ) but the actual wheel is bigger. I do expect the fuel economy to suffer a bit though. I havent driven it enough to see just how much . So far i cant see a difference.
Old 11-06-14, 11:48 AM
josmat
josmat's Avatar
how would 225/55/17 most accurately translate into an 18 in wheel? anyone know?
Old 11-06-14, 01:55 PM
lesz
lesz's Avatar
Received 1,017 Likes on 695 Posts
I was careless in reading your earlier post, and I thought that the IS wheels that you have now are 17 inch wheels.
The tires that come with the ES with 17 inch wheels are P215/55R17, and the tires that come with the ES with 18 inch wheels are P225/45R18. The total diameters of both of those tire and wheel combinations should be very close. According to my calculations, the 18 inch wheels with the P225/45R tires have a total diameter of about 26 inches, and the 17 inch wheels with the P215/55R tires have a total diameter of about 26 1/4 inches. If the diameter of the wheels and tires is not close to being in that range, the speedometer, odometer, and mpg calculations are not going to be accurate.
What is the size of the tires that you are now using with the IS wheels? If you post the size of the tires you have now, I can easily calculate the diameter of the tire/wheel combination determine if you have the right size tires for the new wheels and the ES.
Old 11-07-14, 07:37 AM
josmat
josmat's Avatar
Front Tires Size: 225/40R18
Back Tires Size: 255/35R18
The rims came with those tires so thats the only reason that i got them. Im already looking to get something that better suits my car.
Old 11-07-14, 10:33 AM
lesz
lesz's Avatar
The diameter of both your front and rear wheel and tire combinations is almost exactly 25 inches. So, that puts the diameters about 1 to 1 1/4 inch smaller than you would have with ES rims and the standard ES-size tires for those rims.
You can figure that your speedometer, odometer, and mpg calculations are going to be off by about 1% for every 1/4 of an inch that your wheel and tire diameter is off. So, in your case, the speedometer and odometer are going to be reading speeds and miles that are about 4-5% higher than they really are, and your mpg calculations are going to be about 4-5% higher than they really are.
Old 11-07-14, 01:21 PM
SirW2014
SirW2014's Avatar
Wheel style and color work well with your car color and year model style. Definitely need taller tires to fill the wheel well.
Old 11-10-14, 06:33 AM
josmat
josmat's Avatar
Thanks for that Lesz. 26 1/4 to 26.5 is where ill start with new tires.
another view with the factory rear spoiler now installed.
Old 05-13-19, 05:32 AM
Slexus430
Slexus430's Avatar
Did you ever get bigger tires? I'd love to see an update if you did, thanks!
Old 01-01-21, 05:06 PM
BLexodus
BLexodus's Avatar
i know this is an old thread but if anyone has had success with larger tires on staggered rims I’d love to hear about it.
I purchased staggered rims/tires from an is350 and I’m running 225/40/19s in front and 255/35/19s in back. 19x8 front and 19x9 rear. I would like larger (taller) tires but I’m not sure what the best option would be. Thanks for anyone who can chime in.
Old 01-05-21, 10:02 AM
heyTony
heyTony's Avatar
It helps to use websites like willtheyfit.com to make measurements.
Old 01-05-21, 08:54 PM
RxDuderino
RxDuderino's Avatar
215/55-17 is stock size. 225/45-18 is F-sport size. Going on overall diameter, 235/45-18 is the closest to the 215/55-17. I went to 18's on my 2017 ES, but I wanted a little more cushion. I went with 245/45-18 and have no complaints at all. Preserved the ride and increased handling.
Old 01-05-21, 09:22 PM
BLexodus
BLexodus's Avatar
Looks sharp!
Quick Reply: ES 350 With IS Wheels
