Es 350 front side window- double pane?
03-23-15, 05:26 PM
Quote:
Originally Posted by
jollick
Yes, that photo definitely shows double pane glass.
On your 2015, are the windshield, pano and rear glass all labeled Temperlite?
03-23-15, 05:38 PM
Maybe only the UL has the double pane?
03-23-15, 05:57 PM
Mike728
I just looked at my 2015 ES350
The windshield is Lamisafe
The front side windows, rear window and pano roof are temperlite
The back side windows are Nippon Safety UV
03-23-15, 06:22 PM
jollick
Thanks! So the only difference is the front sides, between the 2013 and 2015 UL.
03-23-15, 08:40 PM
Arty101
I have the UL - and it certainly does not have double pane windows
03-24-15, 08:28 AM
My front two windows are labeled as Temperlite and the top edge is rounded over.
2015 Es300h
03-25-15, 04:25 AM
2014 ES300h UL -> Front side windows are double pane
03-25-15, 05:59 AM
Formula271
I wonder when they made the change. It seems not all 2014 UL's have them.
03-25-15, 02:26 PM
theres your mid cycle change as was discussed before.
04-03-15, 12:04 AM
Mine don't look double paned but they match the 2015 specs, although its an ES300h built in mid-2014 .
Windshield: AGC Automotive Lamisafe
Fronts: AGC Temperlite
Rears: Nippon Safety
04-03-15, 07:31 AM
chromedome
It appears that only the Lamisafe fronts are dual pane. It also seems that even the UL doesn't come with them in 2015.
04-03-15, 03:12 PM
2013 ES hybrid, my front 2 windows are dual pane, the rear 2 are normal. Wish the rear were double as well, i do get a bit of wind noise coming from the rear. Front is quiet as can be.
04-03-15, 05:07 PM
I have a 2015 ES300h, base model, front windows are double pane (V-groove).
04-04-15, 06:51 AM
xclream
Lamisafe? That would be odd they put them on a base model, and not a UL.
04-04-15, 11:50 AM
Seems like there's no rhyme or reason which car gets double pane windows from what I've read here.
