ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
Vibrating while stopped
Old 06-04-15, 11:27 AM
lamikela1
lamikela1's Avatar
Originally Posted by roxy208
I don't understand why they drove it. Only happens when stopped.
My dealer is swamped as well, that's why I had to wait until Monday. I know I'll get the same result. My argument is the RX doesn't do it.
That's the part that I cannot figure out either. I was tied up with work so my wife brought it in (it is her car). If I decide to bring it in again I'll be there to check it out with them. It's really not that bad but when you are in a quiet location it is annoying. Especially since my '08 did not do this. It's really more of a hum than a vibration.
Old 06-05-15, 11:09 AM
Maikerusan
Maikerusan's Avatar
There is no vibration at all on my ES when stopped. I hear some fan noise from the seat coolers if they are on (and obviously the AC or heater), but not a jot of vibration.
Old 06-08-15, 02:28 PM
roxy208
roxy208's Avatar
As one might expect my ES was purring like a kitten this morning at the dealer. My SA thought maybe some bad gas could be the culprit but I don't think so.
He told me to bring it back if it happens again.
It will.
Old 06-09-15, 08:37 AM
lamikela1
lamikela1's Avatar
Yep! Somehow they seem to know when you bring them to the doctor. All of a sudden they get better!
Old 06-09-15, 01:37 PM
Arty101
Arty101's Avatar
I hate it when that happens (or not happens) with intermittent problems. Electrical problems are the worst, and always seem to be fine when you bring it in.
Personally, I don't think it's the fuel and you'll probably forget about it .
Old 06-13-15, 07:55 AM
SLH
SLH's Avatar
It will.
If the engine has any problem in the ignition or fuel system that would cause a misfire, the ECU should record a "code". Every dealer, and almost every independent mechanic, and most auto-parts stores, has an ODB2 Code Reader, and can read that code from the computer...
The nice thing about ODB2 codes is, they don't go away right away. If the engine has a problem, the code stays in the computer for at least a few days.
Absent a code, the engine is very likely working exactly like it should.
Old 06-14-15, 05:32 AM
milliel
milliel's Avatar
I am new to Lexus, but have been working and maintaining my cars for many years. The more accessories that you have on/ working the more load that it puts on the engine. In the old days
we would increase the idle about 50-100 RPM for a problem such as this.. Its not so easy to change the base idle these days. If it continues to be problematic ,I would ask the service tech to increase the base idle
by 50-100 RPM. That should help with the rough idle.
bclexus
02-11-19 12:48 AM
adam2104
07-23-15 02:09 AM
CyberVlad
06-29-15 06:09 PM
SonnyD
08-12-09 03:19 PM
Galaxy 40
06-22-06 08:02 PM
Quick Reply: Vibrating while stopped
